-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   2" shorty (https://www.offshoreonly.com/forums/active-thunder/182662-2-shorty.html)
SCARAB98 03-21-2008 03:36 PM
2" shorty
Has any buddy put on 2 " shorty and gained speed.And stand off boxes.Or tried sportmaster lowers.On a 37' What speed did you see.
Griff 03-21-2008 03:44 PM
AT does not use a conservative X dim at all. I would think a 2" raise would be too much.
Sydwayz 03-21-2008 03:53 PM
Clark has a buddy that spent a lot of time dialing in a 37 in TX with 12" Stelling boxes. It worked well, but it was not a turnkey setup right out of the box.
Rich tried just about every single B1 combination/derivative drive on his 37 with Whippled 525s. The best performance was right back with standard XRs.
SCARAB98 03-21-2008 04:05 PM
Thanks , Sounds like i better not touch anything on the outdrives.
SCARAB98 03-21-2008 06:27 PM
Hey guys do you think stanard xr sport master lower will work ok.I need to replace to lower cases.
ActiveThunder 03-21-2008 07:29 PM
If it isn't running triple digits you will be disappointed. What power?
SCARAB98 03-23-2008 02:55 PM
stock 525s for know.
