Mysterious part.
1 Attachment(s)
Could somebody shed some light on what this fitting is for ? It is on the port side rear next to the engine compartment and It is open to the engine compartment.
There was/is supposed to be a shower in there with a cap that snaps shut over it. Not sure who makes it maybe Perko.
Ok now that makes sense, so I am to assume there would have been a pump and fresh water pick up somewhere in the engine compartment as well ?
Usually it is hooked up to your pressurized fresh water storage tank.
OR u can use it as a flag pole !!!!:rolleyes:
Yep, it feeds from the fresh water tank. It should have come down the tube down the port side gunwale compartment.
1 Attachment(s)
Ok looked around and no luck, Brian would you know the manufacturer of the transom shower units ? not going to add it back it at this time but would like to replace the fitting so can have a cap to close it for the time being and we will remove it over the winter and glass it back up then. Dont need a fresh water shower here in the fresh water, more things to break anyway.
Convert it to an outdoor porta potti! :evilb:
Originally Posted by laszlo01
(Post 2864337)
:ernaehrung004: |
Originally Posted by Thunderstruck
(Post 2864407)
| All times are GMT -5. The time now is 10:05 PM. |
