-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   25 Specs (https://www.offshoreonly.com/forums/active-thunder/247640-25-specs.html)
Ironmanwb 02-15-2011 07:39 AM
25 Specs
I have been asked about a hundered times already about the specs on the 25 I bought does anyone have a full spec sheet on it. I have been going off of ads, nada and whatever else i could find. Thanks for the help.
Griff 02-15-2011 12:02 PM
Exactly what "specs" do you want???
Ironmanwb 02-15-2011 03:32 PM
LOA, Beam, Dry weight, Deadrise, fuel capicity, ect.
I have a pretty good idea about these but I would like to know for sure.
Chris 02-15-2011 03:47 PM
i am pretty sure i have a old spec sheet for the 25, i will look to see if i can find it
boatfreak 02-15-2011 04:39 PM
lenghth centerline.........24'6
beam...........................7'8
weight..........................3975 (approx)
fuel capacity..................65 gal
bottom..........................24 degree deep V
camptappakeg69 02-15-2011 05:05 PM
The spec sheet effective date 5/96 that came with mine is a little different than above..
length.....24'6
beam......7'8"
headroom....56"
fuel cap........70 gallons
weight,complete.....aprox 4350lbs
bottom ..................24degree deep v
Ironmanwb 02-15-2011 06:12 PM
Thank you, the info I had was very close to what you both posted. Thank you very much.
R Addiction 02-24-2011 04:00 AM
Ironmanwb, Which Tantrum do you own?
Ironmanwb 02-24-2011 12:22 PM
I bought DenCams from the board. 1996 w/502.
