-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   37 AVH Question (https://www.offshoreonly.com/forums/active-thunder/272632-37-avh-question.html)
1980Condor460 03-17-2012 10:01 AM
37 AVH Question
If water gets in the cabin under the floor- how do you get it out? I have looked at a couple and have not seen drains at the step. Can water get to that point?
I have been looking at them and am considering purchasing one. Thanks for the help.
ActiveThunder 03-17-2012 10:15 AM
There's a bilge pump in there.
1980Condor460 03-17-2012 10:26 AM
That makes it easy. I look forward to joining the Cult......
Sydwayz 03-17-2012 11:16 AM
It's more fun to back up real fast, and it will shoot out of the bow cleats.
1980Condor460 03-17-2012 01:10 PM
Well I am Ready to Rock......
http://i201.photobucket.com/albums/a...0/7bf4f115.jpg
http://i201.photobucket.com/albums/a...0/df4cceff.jpg
http://i201.photobucket.com/albums/a...0/cc948221.jpg
First stop - Smith Power.
bonesmalon 03-17-2012 06:31 PM
How do you access the forward bilge pump? Mine is on a timer that whenever cabin power is on it cycles 5 mins or so. Supposed to be that way? Why not direct wired with a float? Thanks
ActiveThunder 03-17-2012 08:31 PM
It's a pricey little computerized bilge pump that is self contained. Where it is tough to get to vs. the bilge I thought less stuff to break was better. Yours should be an access hole under the pirelli on the lower step.
If you want to put a switch in you will probably find the wire running up to the galley panel.
Gladhe8er 03-17-2012 08:45 PM
Congrats on the pick-up! That boat has been discussed a lot lately. I saw it in KW and it looked good.
Wildman_grafix 03-18-2012 09:19 AM
Wow that was fast, when you said you were looking you meant it! Cool.
I had a 22 DONZI that had a drain plug in the step,,,,,,,, amazing how much water gets there.
Sydwayz 03-18-2012 12:05 PM
Congrats on the new boat!!
The race boat and a couple others have had drain plugs in the step, but they are not needed. As a backup to the bildge pump, you can stick a shop vac over the thru-hull and pull the water out that way as well.
I have mine wired to the power switch for my water pump. I didn't like it turning on every couple minutes when the cabin power was turned on.
1980Condor460 03-18-2012 05:50 PM
Thanks guys. I just dropped her off in Joplin to start the process.
http://i201.photobucket.com/albums/a...0/4ac4ed80.jpg
ACTIVESHACK 03-18-2012 06:59 PM
Congrats on the new boat and welcome to the Cult. I really like that full cover :ernaehrung004:
bonesmalon 03-18-2012 07:13 PM
Good idea Brian. Maybe I'll hook mine to the stereo. Once the two 800 an one 1000 watt amps are powered chances of me hearing the bilge cycle are pretty slim ;-)
R Addiction 03-18-2012 08:02 PM
1 Attachment(s)
Nice ride 460! I was looking at it a month ago and figured it wouldn't last long at that number. Welcome to the cult and enjoy the Kool Aid!
AJ POWERPLAY 03-18-2012 10:02 PM
That's a killer boat
HavinATantrum 03-19-2012 07:21 AM
You are gonna love this boat, nice. Notice the stitching says Thunder Racing, does anyone know if the Racing part means anything special to the build? Mine also says Racing which makes me ask the question.
1980Condor460 03-19-2012 02:36 PM
Thanks for the compliments guys!
I saw all of the discussions on it - even emailed with Tebo and spoke to Ed about it quite a bit. Virgil and Carl down and Boats Direct were good to deal with. They sent me some up close pics of the paint stuff and the interior before I made the trip and the interior was actually better then I expected in person. I pulled the cover behind the gauge pannel and it was not the speedo hanging from the wires - it was the compass. The Speedo was actually moved over in front of the passenger. Not a big deal to me, especially when you consider it has the Garmin in its place.
I was impressed with all of the documentation that came with it - Original Owners manual, receipts for upgrades and changes, Zul Dyno numbers, etc. I have a long list of updates but figured I would start with doing top ends on the engines, replacing the gimbals, paint the bilge (since the engines will be out) and add a swim platform.
The hard part now is playing the waiting game because Brad is so backed up. I pulled onto his lot yesterday to see a 38 T/S Top Gun with a drive issue, a Blue Cig Cafe, White Lightning, an MTI, Thundercat, Formula and 36 Skater......... could be a couple of weeks before it even gets looked at.
carter38 03-19-2012 04:52 PM
Brad's awesome to deal with first class all the way.
1980Condor460 03-19-2012 05:19 PM
I was thankful he met me up at the shop on a Sunday - a lot of places wouldn't do that and it saved me some more driving.
cosmic12 03-19-2012 07:44 PM
Congrats on the new ride! Looks great love the paint. Just goes to show.....don't listen to all the B.S. ck it out yerself, When Ed said he wanted it I knew that it had to be a good deal. Have fun.
31cigg 03-21-2012 10:26 PM
Brad's is the best place to leave it for sure.
1980Condor460 03-22-2012 07:34 AM
Saw your Cig up there. Very clean. What's he doing to it?
31cigg 03-23-2012 01:07 AM
Had a lifter problem so hes replacing all of them in both motors.
1980Condor460 05-19-2012 08:02 PM
Getting closer.....
http://i201.photobucket.com/albums/a...0/47a207a6.jpg
http://i201.photobucket.com/albums/a...0/aad2d750.jpg
http://i201.photobucket.com/albums/a...0/daaa7cfa.jpg
