-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Whats on everyones summer "to do" list (https://www.offshoreonly.com/forums/active-thunder/273660-whats-everyones-summer-do-list.html)
rssteiny 04-04-2012 05:51 PM
Installing nose cones,, then just boat and party like a rock star.
sleev-les 04-04-2012 06:00 PM
Originally Posted by ACTIVESHACK (Post 3656214)
New indicator cables for the drives. One of my steering rams has started leaking over the winter so a rebuild on them and plan on replacing the rubber hoses with stainless braided lines. New JL Audio amp to replace the Sony that overheats and shuts down. Lastly new Batteries and raw water pump impellors.
Definitely get rid of Sony... They are one of the worst audio brands out there. I used to install audio for Best Buy and we'd get people bringing in Sony all the time because they were cheap. They were way underpowered and if you tried to run them at 2 ohms, they'd overload and go into protect. They were "supposed" to be a 2 ohm stable amp too.
R Addiction 04-04-2012 08:28 PM
Not sure....building a pole barn at home so I can get onto better projects....
https://www.youtube.com/watch?v=-Cb4q3BdHzw
sleev-les 04-04-2012 08:40 PM
Nice....
R Addiction 04-04-2012 08:46 PM
That ought to pick up the pace a bit.:boat:
ACTIVESHACK 04-04-2012 09:23 PM
Originally Posted by ecstatic (Post 3656264)
Mark, I noticed that one of my indicator cables is also cracked. I'll be adding that task to my list.
Once they start rusting and crack it's not long for them. I got the lengths from Pat last week so I could order them. 18' & 22' on the drives and 16' & 22' on the tabs.
ACTIVESHACK 04-04-2012 09:28 PM
Thats what mine is doing. I'm going to take the locker door to a cabinet shop and get some slots routed in it so some air can get to it also.
sleev-les 04-05-2012 05:13 AM
I guess I should have that as part of my list too.. The drive cable has a crack, but is still currently working. Didn't even think twice about it until now haha.
Does the JL have a fan built in? Those help a lot and if it is a class D amp you shouldn't have overheating issues. They are built really well.
ecstatic 04-05-2012 08:37 AM
Thanks for the info. I'll get an order in.
ACTIVESHACK 04-05-2012 09:33 AM
It does have a fan. That's why I'm slotting the door so it can circulate some air.
