-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   383 stroked in a 96' Tantrum? (https://www.offshoreonly.com/forums/active-thunder/278197-383-stroked-96-tantrum.html)
carreraboy1 06-07-2012 04:36 PM
So I had a little bit of bad luck and my motor went last week. Im thinking of replacing it with a 383 stroked to save a couple bucks. My thoughts are it has more HP than my 330 did and will get alot more rpm's out of it. What are you guys thoughts?
HavinATantrum 06-07-2012 08:29 PM
I think you would be better off going with more cubic inches. There are a lot of used 454 motors and maybe find a 502 which is more expensive but will get you to the 60+ mph easily.
REMEDY 06-08-2012 04:42 AM
Yep, get a big block. That small block won't do it.
My Addiction 06-08-2012 04:25 PM
Big block's generally make more torque, that is what will move the boat. You will also have the cost of new manifolds to thinly about
Stormrider 06-08-2012 09:17 PM
Buy both of these for 10k and keep one as a spare.
http://www.offshoreonly.com/classifi...o44621-en.html
Griff 06-09-2012 12:54 AM
Putting an SBC in it would be like putting a V6 in a Corvette.
HTRDLNCN 06-09-2012 01:18 AM
Then again I remember when a V6 S10 Syclone pickup or V6 Regal GN sedan would eat a Corvette for lunch..
I say do it and see what happens. :)
carrera1 06-09-2012 08:12 AM
I have a 454 fresh machined 30 over. needs a set of pistons. cheap....and here on LI
Griff 06-09-2012 11:38 AM
The intercooled turbo chargers on those gave them the power and torque.
