big thanks to the cult at boyne thunder >
Old 07-18-2012 | 09:53 AM
  #31
REMEDY's Avatar
Originally Posted by THE 288 KID
For that much money I think ill have my factory heads worked over this winter! Yikes!
That's actually not bad pricing... If your heads need a bunch of welding and machining to make them work... I suspect they will. I know its a big chunk to swallow, but that's the cost of having these toys. Beware of lowball quotes for your stuff... Usually its low and when they get into it, it goes way up. Most of the time when its done, you could have had the new heads.
REMEDY is offline
Old 07-18-2012 | 12:30 PM
  #32
Talking
+1, do it right the first time. you'll end up spending the same amount in the long run anyway. + you'll make more power
carrera1 is offline
Old 07-18-2012 | 12:37 PM
  #33
Probably your fastest, easiest way to get back on the water right now is to put the new Dart heads on. They are about half the cost of merc heads. Then later in winter they can be ported and do the rest of the package. If your heads are really bad (flange corrosion, guides badly worn etc.) It's more cost effective to use the new dart head. Before they came out w that head you had no choice but to fix them because the merc head is very expensive.
I thought the 525 used edelbrock marine heads. They are not that expensive...no need to buy anything from Merc
JRider is offline
Old 07-18-2012 | 03:21 PM
  #34
REMEDY's Avatar
They are made for merc by edelbrock out of old beer cans. The 525 has a special exhaust flange bolt pattern, therefore the casting is different. An off the shelf edelbrock head will not work.
REMEDY is offline
Old 07-26-2012 | 09:29 AM
  #35
onesickpantera's Avatar
Hey KID any updates?
onesickpantera is offline
Old 07-26-2012 | 10:38 AM
  #36
Yeah, shop finally called me back today after 2 days of trying to get ahold of them. There just getting to it today supposedly. Not impressed....
THE 288 KID is offline
Old 07-26-2012 | 10:51 AM
  #37
jbraun2828's Avatar
Is your boat at ck now? Sucks that your having problems with a newer boat. Keith is always busy and has some serious hardware coming out of there.
jbraun2828 is offline
Old 07-31-2012 | 12:02 AM
  #38
KAAMA's Avatar
Nice meeting some of you A/T owners up there at the BT event....nice showing with all the A/T's I saw and finally met some of my long time A/T brothers up there for the first time. I saw the 33' A/T sitting at the dock as they tried getting it to work, etc,....sorry you guys missed the run....what a heartbreaker----really nice looking boat though!
KAAMA is offline
Old 07-31-2012 | 01:21 AM
  #39
Thanks. She did looks sweet sitting there! I had been looking forward to Boyne since I picked the boat up. Very disappointing is an understatement.
Old 07-31-2012 | 05:38 AM
  #40
LAriverratt's Avatar
damn kidd...sorry to hear you had issues at the run...hope you get your A/T running right soon. You guys summers are a little shorter than ours.
go ahead and Whipple the 525's while your at it!!! you know you want too
LAriverratt is offline
