-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   AT 37 need standart info (https://www.offshoreonly.com/forums/active-thunder/289108-37-need-standart-info.html)
Scarab28Germany 12-19-2012 03:44 PM
Hi
i have a Model 1998 AT 37 non Step
i need for german CE Certifikation some info
Most Boats have a sticker with this info around the driver but i donīt have one.
* how many pasengers maximum
* how is the emty wheight of boat with motors in lbs
* how much is max load in lbs
Does any body know this , o have maybe a picture from this Sticker ?
Thankīs for any help
Hans
speicher lane 12-19-2012 03:59 PM
Here is the website/ contact info for Active Thunder
http://www.activethunderboats.com/contact.html
To satisfy the Zoll you will want information direct form Active Thunder to be considered valid by your customs authority or it will be just a Kopfschmerz of paperwork. Each officer you encounter will want different papers than the previous......
Where would you run a 37' near Lampertheim?
Griff 12-20-2012 12:18 AM
The US Coast Guard does not require the capacity plates/stickers for boats over 25 feet long.
Basically the responsibility rests with the owner or operator of the boat.
Actual dry weight should be about 9500- 10,000lbs.
Scarab28Germany 12-20-2012 06:40 AM
Hi,
Thankīs for the info. didnīt know that you donīt have this sticker
I never got a answer from factory, so i donīt try anymore.
@ speicher lane,
we boat on the river Rhine (Rhein), comeīs from Swizerland thru complete Germany into the Sea.
No speed limit CE is a must have.
Where are you from, if Speicher is your last name it looks also german to me ?
Greatingīs
Hans
