-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   New AT 37 owner....need alittle help (https://www.offshoreonly.com/forums/active-thunder/298744-new-37-owner-need-alittle-help.html)
MILD THUNDER 07-03-2013 01:52 PM
Originally Posted by bonesmalon (Post 3953334)
I'm running 32 B1's Labbed by Cutting edge that's about where I'm at Trim it high and let it fly
How fast? What rpm?
laszlo01 07-03-2013 02:44 PM
29 Hydro P5x with a slight lab finish 12% slip
Macklin 07-04-2013 07:30 AM
Originally Posted by EZEF350 (Post 3953319)
what pitch where your 5 blades? 28 or 30?
I went with 29's so I could keep them stock. They were spot on.
bonesmalon 07-04-2013 08:01 AM
Originally Posted by MILD THUNDER (Post 3953351)
How fast? What rpm?
83 at 5300
boatfreak 07-04-2013 09:53 PM
Originally Posted by TDSTYG (Post 3953030)
I have a guy trying to sell a set of these at my lake? Will this help my 33? I've hit 91 once and 88-89 on most any day with stock 32
Are you going up to Boyne Thunder? I have a set of Hydro's that your welcome to try but I doubt you will be able to spin the all the way up. I think they are 33s so as I say I doubt you could spin them too high but you could still get a feel for them.
Jluloff 07-05-2013 10:13 AM
They say 30s on them or were they worked on to be 29s
Only saw between 52-53 at 3500rpm and ~57-58 at 3800rpm depending on water conditions.....but never saw 60pmh at 3500 since I took delivery ....so about 58hrs put on so far from me...184hr total.
laszlo01 07-05-2013 10:22 AM
Yup was the same i ran when was stock. boat liked them alot
Macklin 07-06-2013 10:28 AM
My bad! Receipt does say 30. Sorry bout that.
I think I remember Laszlo talking about his 29's, but the guy at Hydromotve figured I would need to go up to 30 being in the salt.
John, since you run in fresh, you should consider sending them in for labbing. You will want to get the Bravos tuned first. I had a local prop shop tune them and was not thrilled with the results.
EZEF350 07-15-2013 07:37 PM
so we have the same year boat, and mine is about exactly the same as yours. at 3500 rpm my boat runs 51 mph and 60 at 4000 and tops out at 80 maybe 81 at 5200 w 4blade 32p bravo 1. so r you running 5 blades? brand? pitch?
laszlo01 07-15-2013 08:18 PM
Macklin same issue here, cant remember if was 29 or 30 with final #'s. I will have to look... Either Hydromotive or BBlades both great shops...
