Another prop question. ..
Currently running a 23 mirage lefty that I picked up cheap because I trashed my hydro 25. Like the feel of the 3 blade..but underproped, bumping the rev limit at about 63 mph at 5200 with a little less than 1/3 throttle to go. Should I go bother trying a 25 or just jump to 27 ? Only thing I miss is it takes longer to plane,wonder if that would improve with more pitch. ..or just go back to a 4 blade...but it seems like a 3 blade would be faster.
Allright got a 25 mirage rh....won't be here till next week ...more speed #'s to follow.Running good this year..fresh tune up...injectors were sent out, tested, cleaned.
Alright.. best I saw today with 2 fat guys and full tank was 67.8 at 4800 with the 25 mirage. Conditions were 1' chop with a lot big boat wakes. Think I goin back to a 4 blade!
i run a 4 blade 25p on my tantrum . never checked gps . planes out real good and runs high 60s at 4600ish with plenty of throttle left.
What do you have for power? Had a hydro motive QIV 25 saw 70 for the best. .but lite load running on fumes
modified 502 550hp ish . should run mid 70s . havent had a good chance to run it wide open trimmed out since my rebuild . taking it iut all next week on vacation hoping to really see what she can do .
Sweet...mine pretty much stock except for gill exhaust and ecm reflash. Guessing about 425....almost time for refresh has about 470 hrs
I have a hydromotive p5x 24 pitch right hand) that I don't use. I changed my gear ratio and this prop no longer works for me. It is in good cond. (never worked). make reasonable offer if interested. (No hub).
ray |
Originally Posted by raytart
(Post 4152185)
ray |
(Post 4152185)
ray Too bad its not a left, I am looking for a lefty 5 in that pitch range |
