Bow light thru hull drain???
I'm looking for the flush drain fitting on the bow of a 33 or 37AT. My anchor locker has a 5/8 opening and a flange that hangs over to hide it. When I back the boat off the trailer the flange snags my bow stop, I want a flush mount fitting but an having bad luck finding one. Anyone know where I can get the thru hull fitting that are on the ATs
I thought that was a vent, not a drain....
Originally Posted by Pwraddr
(Post 4175349)
(Post 4175349)
(Post 4175563)
It's a drain for your pop-up bow light.
Yeah so where would you guys find a replacement at?
Not sure what the newer AT's use, but most fuel vents are 5/8"
Maybe these??? http://www.cpperformance.com/p-348-b...l-vent-58.aspx |
The drain on the newer style pop up lights is pretty small. The hole is at best 1/4" with a flush collar around it that's not much more than an 1/8" ring. It's a pretty stealth looking piece.I'm pretty sure the pop-up light is from Accon, not sure the drain is theirs though. Why don't you just get it over with and order a new Active Thunder? It'll come with it already installed, what could be easier?
Originally Posted by 509 SC
(Post 4178563)
| All times are GMT -5. The time now is 09:23 PM. |
