Originally Posted by boatnt
(Post 4192930)
you should try running them again when the lake kicks up a little, the results might be a little different.
Mine actually loves a good white-cap chop the best. I lose speed in glass water!
Originally Posted by Gordo
(Post 4194663)
That's classified
I could tell you, but I'd have to Kill you. :whistle: |
(Post 4194704)
That's classified I could tell you, but I'd have to Kill you.
I don't think Gordo is kidding.
What power do you have? I have a nice custom solid hub 28 B1, 1" shaft. I have a 1 1/4 shaft now so I cant use it. |
Originally Posted by mgh
(Post 4194705)
23P 3 blade mirage?
Actually, It's a 28-ish Bravo 4-blade that went thru a few adjustments before it was perfect. |
(Post 4229044)
But it's a really pretty Mirage... :whistle:
Originally Posted by SHORTFUSE
(Post 4229459)
Is there any way for your prop to be duplicated. I had BBLADES do mine a few times. It's close, but not perfect.
His prop specs might not work for your boat. |
| All times are GMT -5. The time now is 09:54 AM. |
