-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Side cockpit panels (https://www.offshoreonly.com/forums/active-thunder/319027-side-cockpit-panels.html)
Pwraddr 10-11-2014 08:16 PM
Side cockpit panels
How in the heck do they install them? No way I can reach the top nuts.
Wanting to remove them, any tips are appreciated. The ones directly inside the gunwales are doable, can't figure out how to reach the rest.
Drew555 10-11-2014 08:21 PM
Do you have any midgets?
Pwraddr 10-11-2014 08:36 PM
Thought about trying for 4 year old daughter but subwoofer is on one side and water tank on the other.
Drew555 10-11-2014 08:58 PM
If you have a welder weld box wrench to a metal extension and use a mirror . Best I can think of. Good luck. Btw my youngest is 2yo and is good with a wrench.
Sydwayz 10-11-2014 09:05 PM
Pull out the speakers to reach a few high/forward ones.
As for the rest, you need to literally crawl up in there. I've done it a few times. It's tight. You may need to find a small friend.
Pwraddr 11-23-2014 06:05 PM
Not looking forward to this job.....was hoping there was something I was overlooking.
Sydwayz 11-23-2014 06:58 PM
Ratcheting wrenches are your friend for this task.
Scarab28Germany 11-28-2014 05:05 PM
Hi,
I just removed mine, but it's the older 99 model. I removed all other nut's. Then underneth there is a big hole and i
was able to come to the highest nut. It was covered with Fiber Glas. I don't know why it was covered but it took me 2 hours and a blood emty arm to get it off. After that it was posible to take the top front nut of.
Maybe you have also such big holes under the side panels. I saw them thru the side storage.
Maybe that help's
Pwraddr 11-28-2014 05:53 PM
Danke!
I will invest some time in the spring time. Cold here in Detroit now and the boat is not in heated storage.
Originally Posted by Scarab28Germany (Post 4226880)
Hi,
Maybe that help's
Relaxing 11-28-2014 08:36 PM
Originally Posted by Pwraddr (Post 4226903)
Danke!
Toughen up, its not like you just moved to Michigan. Get you a little heater and get started.
