A peak inside the 37AT superstructure: >
Old 03-03-2016 | 08:44 AM
Originally Posted by ICDEDPPL
Whats the latest trend on the gas tanks? Do they stay as is in picture or do they get foamed in?
no idea ICE'D, but I gotta stop drinking, starting to see double on your avatar
Excess is offline
Old 03-03-2016 | 10:38 AM
I don't see any pics - is that because I'm not in the club???
ALL_IN! is offline
Old 03-03-2016 | 04:07 PM
I see double doubles,,,
TWIN-SPINS is offline
Old 03-03-2016 | 08:30 PM
ActiveThunder's Avatar
Actually, a great question.
The tank manufacturer recommends we put 1/4" rubber mat under them and simply thru-bolt. This is based on the thought process of water under the tanks and corrosion. Plus replacement.
Anybody that has ever tried to remove a tank know if it is foamed in you almost can't get it out. It becomes "structure".
This picture was with rubber mat and thru-bolts. However I then foamed them in with 6 lb density foam. It is part of the structure.
Pat
ActiveThunder is offline
Old 03-03-2016 | 09:31 PM
BUP
Pat hard to tell in the pics but is your aluminum fuel tanks externally coated to help against corrosion issues down the road. Just asking
Something like these in the link
http://www.speedytanks.com/gallery.html
If not there is products today to even clear coat them or even bed liner coatings.
What are your stringers made of ?
BUP is offline
Old 03-04-2016 | 04:36 PM
I went back and forth and ended up just doing the rubber strips on mine without the foam... I think it`ll be ok too.
ICDEDPPL is offline
Old 03-04-2016 | 05:19 PM
BUP
^^^^^ according to your picture it looks like you have additional huge structural sound twin fun bags that your fuel tank can be mounted in between for the extra support needed to handle those rough days of offshoring. ^^^^^^^
BUP is offline
Old 03-04-2016 | 08:26 PM
rak rua's Avatar
^^^^^ Seen it before, wait 'till those tiny stringers break during a hard pounding and reveal moisture in hard to reach areas. Looks good now but when she gets older, the keel pad will get wider and stress cracks will appear out of nowhere ^^^^^
rak rua is offline
Old 03-05-2016 | 10:26 PM
It's a Cult, not a club!
Fischan is offline
Old 03-06-2016 | 11:13 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Divinycell
Sydwayz is offline
