-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Rub rail replacement (https://www.offshoreonly.com/forums/active-thunder/336411-rub-rail-replacement.html)
Faster Daddy 04-14-2016 11:17 PM
Changing a lil color and repairing all the clear coat issues. Pulled rub rail off and would like to replace with new. Called AT to see about getting it, but haven't had a call back. Anyone know where to get it from. Boat is a 37AVH with white rub rail. Thanks!
Griff 04-15-2016 12:17 AM
http://www.rubrails.com/ is one source.
Pretty sure it is made by Taco Metals.
Faster Daddy 04-15-2016 12:45 AM
Thank you sir I'll start there in the morn!!
ActiveThunder 04-15-2016 06:18 AM
Assuming it is white with stainless insert it is Taco products:
Rub-Rail Insert S11-4511P20
Rub-Rail V21-9613WHC20D
Faster Daddy 04-15-2016 06:48 AM
No sir it's white only. Older 2000 model...Mark House had it originally. Sure not opposed to upgrading tho if that's what's going on them now days. Have other questions for you as well, so if there's any way possible please give me a call at your convenience at 830-459-1530. Thank you very much sir, Larry.
