new steering wheel
Hey guys, I want to change my steering wheel on my savage. Can,t get the old one off. That big bolt just keeps spinning, not really sure how to remove the old wheel. Any help would be appreciated. Thanks Chris
Do you mean the center nut is spinning?? and not coming off??
Does you new wheel use a different hub??? You will need to use gear puller to get the hub off but the wheel has to be removed from the hub first. |
New steering wheel
Yes I have to change the hub. The problem is it looks like a big bolt instead of a nut that keeps spinning. Looks like it goes through the rack and pinion. I think that's what it's called. Do you have any idea what brand steering it might be? its original
Originally Posted by toyboat991
(Post 4625341)
Do you have hyd steering???
And yes, post a pic. Anyone can post pics directly from their phone now. |
It should look something like this if its hyd Latham Marine
Even cable systems are basically the same. Its a tapered keyed shaft with a nut. |
New steering wheel
No it doesn't look like that. I have the twin piston hydraulic assist. I'm going to try and figure out how to post pictures. Stay tuned and thanks.
Not sure what you have. I had twin ram hyd add on steering on my Pantera with a cable helm.
I changed that wheel and it was the same tapered keyed shaft that my full hyd helm that my AT has. |
New steering wheel
New steering wheel
This is what I have. Hopefully the pics posted
Won't the new wheel and/or hub mount to those 6 flat head allen screws?
Most I have seen have a tapered center shaft with key way in the center, not the through bolt like you show. But the wheels I have had mount to hub with screw pattern that looks like what you show around the outside. |
Never seen a set up like that. I assume you just have take off the nut on the back and pull the bolt out.
Originally Posted by RSCHAP1
(Post 4625934)
| All times are GMT -5. The time now is 03:10 PM. |
