Re: troubled 37
SPICY will do i think i'm going to see him this weekend and help him kill a case of cans unless he has to work again.BARNEY is the man when it comes to painting in my area.
Re: troubled 37
Rich,
Which hatch is leaking and can you actually see it dripping? Pat. |
Re: troubled 37
Rich,
Re: troubled 37
Great looking paint job. Every new boat has a few little gremlins, remember in the world of custom boat builders these problems are next to nothing. Good luck with your new ride.
Mike |
Re: troubled 37
I was suprised at all the water in that boat when I test drove it. The hatch appeared to be sealed well, but it looked like the deck was slightly skewed where the hatch was, which looked like the hatch was askew. Could that be the problem???
Re: troubled 37
The 525 in my fountian will leak about a quart or two till the rear main blew out last weekend. Ran fine at lake anna then went to the river and blew oil over the exhaust. So off to the marina to get fixed, the fuel must be common for all of them mine is doing the same thing. Rich if you are a mercury dealer then I need to get with you about my ecu if I keep the boat.
Terry |
Re: troubled 37
There has been a service bulletin on the 525's from Mercury on the rich condition of the engine with black soot on the transom's and I think that may be where your raw fuel out the exhaust is coming from. YOu can carry this into a Mercury dealer and have the engine reprogrammed to eliminate this condition. I have 525's and I have this problem with the rich condition but no oil usage problems. That is way excessive on your boat and Mercury should take care of it under warranty.
Re: troubled 37
Terry |
Re: troubled 37
I came by your marine on saturday but you looked busy talkinf to customers abotu the pontoon boats. Was hoping to talk to you at andys but James said you were out of town. The oil leak was fixed at haynes outdoors it was a cracked oil pressure sending unit. I am gettting the ecu reprogramed. I talked to andy and he said you are sellin the new merury five blade. I need to talk to you and come down and try one out the fountian has alot of prop slip.
Terry |
Re: troubled 37
2002 37 Active Thunder with t/675 Eickerts..100mph..Priced to sell NOW.
Great deal for the right buyer...100% ready to go...Motivated!!! |
| All times are GMT -5. The time now is 02:59 PM. |
