-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Props for my 25 (https://www.offshoreonly.com/forums/active-thunder/9636-props-my-25-a.html)
camptappakeg69 11-02-2007 04:41 PM
I run a 25 hydromotive on mine not in the best of shape, BBlades thinned and reworked it best they could last winter.
best I saw last year in the early spring(colder water and air) was 69-70 @ around 5000 rpms.
harsin 11-02-2007 07:33 PM
1 Attachment(s)
Originally Posted by johnlaskowski (Post 2325203)
no ushally its me and the old lady and thats it. i know this is what im going to hae to do but i cant justify buying 5 diff props to test i just wont spend that kind of money. thats why im hoping someone on here has already kinda gone this route and can point me in the right direction. so if you say try a smaler pitched prop will give me better results up on the top side? im not trying to be a pain at all just hoping to absorb as much knowledge from u guys as poss to help me along my way.
Hi John The prop that's on the boat has been repitched to a 24 or 25 pitch. It's stamped on the hub RP then the new pitch . The drive is a 1:36 gear ratio and reverse rotation prop, I didn't seem to get as much prop torque that way. I was thinking of changing the gears to a 1:5 ratio so I could run a larger prop, don't know if it would gain speed or not, maybe Gordo or someone else on here would know? What kind of speeds are you getting on GPS with 2 people on board? [ I didn't have a GPS on boat when I owned it ] Here's a copy of dyno sheet pull #7. How's the trailer doing with the new tires? Hope everything's going good.
Morry
chuckbeecher 11-02-2007 08:31 PM
Try the Rev4. With the additional hp a 25 may do the trick.
Talk to BBlades..he knows his sh*t. The Rev4s are a little known Mercury secret.
ACTIVESHACK 11-02-2007 10:05 PM
My earlier post mentioned the Rev 4. It set my neighbors Haha on fire. :boat:
R Addiction 11-03-2007 11:09 PM
Morry, Key West this year? We'll bve down tuesday to tuesday:ernaehrung004:
johnlaskowski 11-04-2007 08:42 AM
hi morry and yes the trailer is fine. boat is in storage for the winter. just seing what i can do or it next spring. hows your new boat coming along. hopefuly in the spring we can get together up here some time. w/ 5 people it ran out at about 75 and i ran out of lake couldnt trim it up. so with 2 i have no idea we'll see next year!
harsin 11-04-2007 09:29 AM
Hi John and Leslie We'll be there Tuesday thru monday. We're staying at the Customs House right beside Hogs breath. Don't know if it's a dump or not, place to sleep a little. Hope to see you guy's there. cell 317-502-2812
Morry
R Addiction 11-04-2007 03:41 PM
We'll see you down there Morry. We are staying the same dates. Keep your phone on!!:ernaehrung004:
