-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Hull design (https://www.offshoreonly.com/forums/active-thunder/9668-hull-design.html)
candyman35 01-25-2002 03:06 AM
Hull design
The 37' with it’s large step reminds me allot of the mid 90's 30' Challenger hull. I saw it at IMTEC and had gotten some information on it. It was specifically designed to work with the Black Hawk drives. Has AT tried to put the duo-props with this Hull and what were the results?
Thanks,
Dan
ThunderousDaze 01-25-2002 07:12 AM
The AVH was designed by Harry Schoell and is patented with Washington DC. Harry has done a lot of work out there and is extremely good at what he does. I can send you some additional info on Schoell Marine. Did you get the CD?
candyman35 01-25-2002 05:04 PM
ThunderousDaze,
I did not receive the information yet. After doing some more research I see that Harry Schoell also designed the hull I was speaking of. From what I remember it was very efficient like yours.
Thanks,
Dan
thunderdan 01-25-2002 07:24 PM
and do not forget, "man does it look good too." ;) :D :D
