-   Active Thunder (https://www.offshoreonly.com/forums/active-thunder-30/)
-   -   Need help Pat!!!! (https://www.offshoreonly.com/forums/active-thunder/98420-need-help-pat.html)
32 thunder 03-15-2005 11:39 PM
Need help Pat!!!!
Pat I took the bolsters out of the 96 32 active thunder I want to replace the screws that hold them in can I go alittle longer on them or is there something underneath them??
Jason
Griff 03-16-2005 02:11 AM
Re: Need help Pat!!!!
Try putting a piece of wire down the holes and see how far it goes. Might have fuel tank below the mounts nearest the center of the boat. Longer won't really do much if the floor is an inch thick.
You may also have a boat built prior to Pat owning AT.
ATPatrick 03-16-2005 05:59 AM
Jason,
Griff is correct. The tanks are just below the floor proabably less than an inch. The coat hanger probe is a good idea. We currently have an aluminum plate we attach under the floor. If your pirelli is still out you might explore this option as well.
Pat.
Miller 03-16-2005 04:50 PM
Pat, I like the new avatar!
ATPatrick 03-16-2005 06:27 PM
Miller, I will have another new one tomorrow night. stay tuned.
Miller 03-16-2005 06:28 PM
I'll see it Friday morning...traveling all day tomorrow! But, I'll be interested to see what you come up with! :D
miller
Miller 03-17-2005 09:05 PM
That's a great AVATAR! Long live the IRISH!! :D
