-   Advantage (https://www.offshoreonly.com/forums/advantage-45/)
-   -   advantage 32 victory prop? (https://www.offshoreonly.com/forums/advantage/216558-advantage-32-victory-prop.html)
seanmcg 09-09-2009 05:26 PM
I have a 32 victory with HP500's. does anyone have suggestions on the best prop and pitch to run?
Advantage_Rob 09-14-2009 08:56 AM
PM sent.... I run 30P bravo's with 502 mags... tried alot of props & only a bravo prop would get the 32's hull on plane, everything else i tried blew out instantly. Mine are not labbed, but a lab with a little cup added to the prop would be my next step if i was worried about that last few mph but im not ;) I can pull 30's to 5000RPMS so all i can say is try some 30's & see what RPM"s your 500's can spin em up to. I think your shooting for 5400RPM's with the 500's. Props are a try & see thing....
the bear 09-17-2009 07:44 AM
I have 496 hos on my 32, and I run 28 bravos, 4 blade, 5200 rpms, I am going to try 30s, but have been told I will have to lab them to get the RPMs I want, but will try anyway.
firegyz 08-01-2012 06:06 PM
Prop
Have 2004 32 victory br with 525efi's use hydromotive 30 pitch 5 blades work great.As of now they are stock but seem great for now.
