-   Advantage (https://www.offshoreonly.com/forums/advantage-45/)
-   -   84.2 mph on bravo 24 tubin prop (https://www.offshoreonly.com/forums/advantage/304791-84-2-mph-bravo-24-tubin-prop.html)
schnydo 10-30-2013 07:03 PM
https://www.youtube.com/watch?v=3OTa6G_NpoY
22 Sport Cat 11-03-2013 06:13 AM
Originally Posted by schnydo (Post 4019294)
Nice Video
22 Sport Cat 11-03-2013 06:19 AM
I just put my 22 together.
How do you deal with the porpoising, not much trim?
I came from a 32` V hull and this boat is much different.
schnydo 11-03-2013 03:33 PM
You will see me put the tunnel tabs down a little bit with my left hand as soon as it airs out they are brought all the way up then there is no porpoising until u slow back down
22 Sport Cat 11-04-2013 10:38 AM
Thanks...my motor dynoed at 700hp so I am hoping to get numbers like you.
schnydo 11-04-2013 08:09 PM
I have 575-600 runs 100MPH 29 PITCH 136 GEARS let us know
22 Sport Cat 11-06-2013 06:01 AM
That sounds awesome, what size carb are you using?
schnydo 11-06-2013 07:26 AM
1050 motor is a MERC 525SC + intercooler,msd
22 Sport Cat 11-06-2013 05:11 PM
Mine is a Holley HP 850...made 700hp at 6000 RPM`s, MSD, CMI completely dry exhaust system. I may have to increase carb size to get enough flow. What are your RPM`s at WOT?
Dart Big M block 540ci, all the good stuff inside, figured I`d go large so I didn`t wish I did later
schnydo 11-06-2013 08:44 PM
5800
