Re: 4 Blade or 5 Blade prop?
4% slip, that is amazing for a pleasure boat
with the numbers you have i get 7%, still good,what was prop shaft to bottom? i am working on a buddys 26 daytona an am unfamiliar with eliminator set ups.
almost 2" above the bottom of the outer keel lines. mine had a delta pad 2 step bottom so off the center pad it was about 3 1/2" below that.hope this helps
| All times are GMT -5. The time now is 02:53 AM. |
