-   American Offshore (https://www.offshoreonly.com/forums/american-offshore-56/)
-   -   500efi with Procharger Application for 26ft AO (https://www.offshoreonly.com/forums/american-offshore/184895-500efi-procharger-application-26ft-ao.html)
Colorado26AO 04-19-2008 08:22 AM
I wanted to see if anyone has dropped a 500 EFI motor with a M3 procharger application before in a 26 ft AO. The boat is a 2001 2600 O/S. If you have, does everything fit ok in the engine compartment or do you need to cut the hatch? It has the 504 intercooler on it as well so I hope there is enough room in front of the motor. Just wanted to see if anyone has had any issues trying to get everything to fit ok.
chromecat 04-19-2008 10:41 AM
I'm sure DrewDown will reply, but he addded a vortech (i think) supercharger to his 2600.. I believe he had no trouble getting it all to fit under the hatch.
Don
DrewDown 04-19-2008 12:03 PM
Chrome cat is correct. Everything that came with the vortech fit underneath the hatch and there was enough room in front of the motor for the extra pully. I would call Bob Endress from Vortech. Super nice guy and will take the time to answer all of your questions. I belive vortech and procharger are manufactured in the same building so he probably could answer you questions on the procharger. If your not stuck on the procharger I would highly recommend the vortech. I still keep in touch with the current owner, he just did a compression check and it came back good in all 8 with 270 hours on the motor.
chromecat 04-19-2008 11:11 PM
How fast was your 2600, and how much boost were you running?
Don
DrewDown 04-20-2008 10:23 AM
I could squeeze 102 out of it. 5lbs of boost.
