-   American Offshore (https://www.offshoreonly.com/forums/american-offshore-56/)
-   -   04 26 ao Fuse Panel? (https://www.offshoreonly.com/forums/american-offshore/211716-04-26-ao-fuse-panel.html)
crowntow 06-24-2009 07:43 PM
Where is the fuse panel hiding?
chromecat 06-24-2009 08:33 PM
what fuse ??
crowntow 06-25-2009 06:24 PM
All the fuses does it have a fuse panel?Bilge pumps for starters.
chromecat 06-25-2009 10:38 PM
that year should might have circuit breakers which have resets either above or below the switches... if it has fuses they should be right there also. send me some interior shots of the boat and the switch panel and I can see if it jogs my memory..
[email protected]
Don
chromecat 06-25-2009 10:40 PM
also... what boat is this... nxs or 2600.. what power, where did it come from... trying to figure out what boat you are talking about... who owned it previously...
Don
quest 06-25-2009 10:52 PM
we used several different configurations. most 2600 s had circuit breakers with reset buttons located in the switch pannel on the dash. the fuse for the hatch openers was located under the drivers seat. mercury motors have a 50 amp circuit breaker located at the rear of the motor adjacent to the ECM. it is a red button. the starter motor wil not work if this circuit breaker is not reset. also the shifter must be in neutral because of a neutral safety switch built into the shifter. the bilge pumps were hot wired in and not protected by a fuse. the only place we put fuse pannels was behind the dash when we did not use the circuit breakers in the switch pannel.
crowntow 06-29-2009 06:47 PM
Thanks for the info that helps.Boat is not a nxs I bought it from shrogren this past winter.Motor is a blown 540 Joey Griffin built whatever thats worth.Anybody know the boat?
gtsmpuc 07-01-2009 12:51 PM
On my buddies his are right under the switches. They are square covers and the fuses are in them. I think they are supposed to light up or something. They dont look like fuse holders, but they are.
