98 3100 questions
Have a few questions about a 98 3100, 500efi's, standard bravo's- no boxes
What is the porpoise range, 65-75? What kind of speeds can be expected with the stock 500efi's What prop pitch, assuming the drives are 1.36 -- trying to verify Thanks in advance!! |
porpoise can range from 75-85 depending on the water conditions
500efi's should run low 90's 30P 4 blade bravo |
Originally Posted by FASTTIMES
(Post 3516053)
That boat should run mid 90's all day in good tune. I would say 1,5 is the ratio you want.
Wannabe |
I have 500HP's carb in my 98 31
30p 4 blade Bravo slight porpois 75-80 |
Standard length lowers? That makes a big difference on a 31. I have a 98 also.
| All times are GMT -5. The time now is 11:42 AM. |
