AO v. Awesome
On the 31's other then the dash, is there any other differences in the boats. Ie the lay up and set up? Can you get the same performance from an awesome as from an ao?
Awesome
Early 90s awesomes seem on the heavy side. They both have the same bottom. The Awesome has a different floor liner with a little less room between the seats...thus a little more room in front of the engines. In my opinion they are alot of boat for the money in most cases.
I will add to Greencard:
1) Deck and cockpit liner slightly different. 2) Awesome had a seperate dash panel mold. 3) 97-up Awesome had front footwell inserts 4) Fuel tanks further forward on the AO. 5) Bravo transom cutout slightly different between the two. My observation is the AO has the drives a tad closer together. #4 only relates to the cockpit liner and not necessarly the hull. |
Hey guys, have any of you weighed your boats? Interested to know the diff between an 80's chris, late 90's AO and Awesome. Mine on the trailer is 12800. That's a big piggy for 31'!
holy chit, thats heavy for a 31' I assume you have a steel trailer? I'm curious to know the weight difference as well. I actually believe my '95 Awesome was lighter then my buddies '99 AO, Mine sat much higher in the water when rafted next to each other, never weighed my boat, but I have an old brochure from back in the day that calls the Approx. dry weight @ 6200LBS:lolhit:
Originally Posted by AO31
(Post 3525165)
WOW :eek: if your steel trailer even weighed 2000lbs that would put the boat over 10k. something seems wrong here as I would like to know what they weigh off the trailer. My boat sits about 6" lower in the front than the Awesomes do. Maybe Art can jump in here and post the weight from the factory.:readinghelp: IMO my boat weighs too much in the front end. |
Originally Posted by Ran-Dom 32
(Post 3525501)
12K Wow. |
Phil, mine is a '98 and I too feel the nose of the boat could/should be lighter. Will try to run across the scales again on Sat with and without boat on trailer and gather some more info.
I like my awesome didn't get to use it but twice this summer"couple of boat problems" but got Keith Scroggins to get things back in line. But was just wanting to know the difference. Been so ticked at the boat lately and was thinking of getting rid of it. But the boat is just to nice to get rid of.
Ao31, is your boat a speedmaster boat? The drives, extension boxes, trannies, etc... can add up pretty quick.
I just went to the cat scales and my boat weighs 10,900 lb. Tounge was 540, axles were 10360. Boat, trailer, full fuel tanks, some gear, with xr drives and no stand off boxes.
94 3100 Awesome Thundercat Thanks, James |
The one thing no one mentioned as a difference is the gravel guard on the top deck on an AO. Also the motors on an awesome are not in the same side to side location as an AO. I will try to weigh mine next time out. Speedmaster/trannies add up.
Originally Posted by tssteph
(Post 3526557)
That is a good point. I think a big difference is in how the cabin is layed out. It seems there is far more plywood used in having the the bed runing side to side and that extra storage to the left rather front to back. Art had told me that the 2000 models and up were far much lighter then the earlier models. |
sorry guys the weight range with empty tanks but fully rigged is 6500 lbs(lighest) to 8400(heavest) if it weighs more it has soaked up a lot of water, trapped water someware, or there is a hidden compartment in it with AL Capones gold.
How much do the trailers weigh. Gas was something like 8 lbs per gallon so 120 gallons is about 960 lbs.
Originally Posted by quest
(Post 3526817)
...or there is a hidden compartment in it with AL Capones gold.
Originally Posted by hwyrnr
(Post 3526864)
How does Chris Craft compare??
(Post 3526817)
is this with or without the trailer? |
My boat sits about 6" lower in the front than the Awesomes do.http://www.youngbin.info/jie4.jpg
| All times are GMT -5. The time now is 09:25 AM. |
