-   American Offshore (https://www.offshoreonly.com/forums/american-offshore-56/)
-   -   Blew motor. Will this one work. (https://www.offshoreonly.com/forums/american-offshore/299081-blew-motor-will-one-work.html)
N2spd 07-01-2013 07:47 AM
Spun a rod bearing and bent pushrods. Found a 454 stroked to a 496. Aluminum heads 112 degree lobe seperation. 575 hp/600tq forged internals. 4 bolt main. Will be run in fresh water only. I have a xr outdrive. Also what prop should I start with on ghis setup? Have a 29 x14.5 4 blade cleaver and a 25 x14.5 3 blade mirage. Thanks for your help. The motor is not marine but everything around it will be.
flysfloatsor 07-01-2013 08:03 AM
Do you know what the compression ratio is? Thats going to dtermine if you can buy gas on the water.
N2spd 07-01-2013 09:55 AM
Might add its a 1997 ao 26' cat.
N2spd 07-01-2013 09:56 AM
Its 10:1
