Originally Posted by 88bullet
(Post 4250376)
bought the cougar huh?
Not doing boxes just a swap out from the cougar to the Apache and run the snot out of it. Stick with the setup as it sits 4 blades no boxes
Its worth more with bravos
No it's not
just busting your balls. should run like a scalded dog. good luck with the build!! will it be the only 36 with speedmasters?
(Post 4250718)
No stepped ones that I know of.
Only stepped with SSM I know a few straights have them. The purple with yellow interior had SSM III on it
My 36' and none of the 36's, to my knowledge, have notches. I say go higher as well but without a notch you might be limited how high you can go unless you add boxes. Bobby's not a big fan of boxes on his boats. May wanna give him a call.
There were a bunch of straight bottoms with SSM 3's and 6's. Some were side-by-side, a few short stagger and a small percentage full-stagger. Also, Bobby and Pompi got the X setup really well on the new Warpath with Illmor's and your bottom so they may be able to tell you where to put the drives.
| All times are GMT -5. The time now is 06:58 PM. |
