Marine Mods CAN-2-CAN Gateway
From Wikipedia, the
free encyclopedia "A Controller Area Network (CAN bus) is a vehicle bus
standard designed to allow microcontrollers and devices to
communicate with each other in applications without a host
computer. It is a message-based protocol, designed originally
for automotive applications, but is also used in many other
contexts."
What Are CAN Gateways ?
The role of a CAN Gateway is to be the isolator and translator between
different devices (Nodes) and/or multiple CAN bus networks. These
could be computer interfaces, analog adapters, digital displays,
gauges, actuators, ECM's and more. Gateways bridge the physical and
data-link layer, as well as higher application layer protocols. Think
of them as routers or firewalls for mobile networks.
What Makes Our Units Better ?
Marine Mods CAN-2-CAN Gateway was specifically designed to be a physical isolator
and protocol translator for specialty power-train components used in
performance boats. Also popular in harsh environments like
off-road vehicles that require rugged water tight components. Our
gateways allow CAN devices to safely communicate using different
languages, speeds, and power sources. The units come pre-programed
to fit each customers specific build. Diagnostics, upgrades, or protocol changes are easily made via a built in micro USB connector. We think you'll find these units not only feature packed, but also the most affordable custom gateway option on the market today.
What Protocols Are Covered ?
Our first release version in 2015 was programed to translate Holley
EFI data to NEMA2k marine chart plotters or gauges. Since then we have updated hardware, and expanded protocol options to meet customer demand. Including J1939, AEM, and high speed GMLAN, covering GM's LS and Duramax engine platforms. New options are added as requested. So if you need something special, don't hesitate to ask.
Unlike the competition, our units were designed specifically for easy installation in very custom applications. You don't need to understand programing languages or buy special adapters to make changes. A simple one click process loads the firmware updates. Below is a
screenshot from testing on a Simrad NSS12 display. All data was generated with two gateways running in "demo mode". This setting is an
easy way to setup your displays without wasting fuel at the dock. Once completed,
switch the gateways into live data mode and your ready to go boating.
Common network designs, installation photos, and schematics will be
available in our Tech Corner section as time
permits. For now, feel free to contact us with any questions you may have.
Our Services
We offer custom ECU tuning, specialty product design and
fabrication services. Along with custom rigging advice on
powertrain conversion.
- Marine Embedded Electronics
- Custom Wiring Harness Assemblies
- Specialty App Development
- EFIlive and Other ECU Tuning
- Custom Duramax Rigging Parts
Our News
[July 1 2015]
Registered the domain marinemods.us
Needed somewhere to store bunch of stuff I've collected relating
to go fast boats mods. The dot com address I really wanted was
taken..
C2C Gateway - Rev 2.0
A Small Case Packing Big Power
Online Orders Receive
Free Shipping:
Hardware Features
- ° Galvanic Isolated
Transceivers
- ° ARM Cortex-M4 processor
- ° Ultra Low Power Consumption
- ° Micro USB Port For Upgrades
- ° Power and Bus Status LED's
- ° IP67 Water Tight Enclosure
- ° DeviceNet Micro-C Connectors
- ° 1 Year No Hassle Warranty
Switchable Settings
- ° Port / Starboard Engine
- ° Demo Mode / Live Data
- ° 120 ohm Bus Terminators
- ° USB Programing Mode
- ° USB Diagnostic / Debug Mode
N2k Output Example
RPM – 10Hz Rapid Updates
» Boost / Vac – 10Hz Rapid Updates
» Fuel Pressure - 1Hz Updates
» Fuel Rate / GPH - 1Hz Updates
» Coolant Temp - 1Hz Updates
» Oil Pressure - 1Hz Updates
» TPS / Engine Load - 1Hz Updates
» Alternator Voltage - 1Hz Updates
» Drive Trim – 10Hz Rapid Updates
via Holley Aux Input #1
» Trim Tabs - 1Hz Updates
via Holley Aux Inputs #2 & #3
