Thermo-Lite Board ® Product Line
SpaceAge Synthetics' Thermo-Lite Board ® is a unique closed cell, lightweight composite product manufactured with cross-linked polymer foam and fiberglass, offering high specific strength and toughness.
The non-absorbent material is extremely durable and dimensionally stable, provides an excellent bonding surface, has good impact strength, sound and thermal insulation, and is resistant to contamination and high temperatures.
Offered in sheets or cut into parts, our material is built for lifetime performance and is ideal for endless coring applications subjected to static and dynamic loads.
Our Thermo-Lite Board ® is manufactured in a thicknesses from .25" to 2", dimensions up to 60" wide and 170" long, and a density range of 10-40 lbs/ft³, depending upon the product line.
Please contact us, and together we will qualify a product line to meet your applications.
Thermo-Lite Board ® Core
Manufactured with polymer foam and a filter fiberglass lay-up, this product is a good coring material in niche applications. Available in a density range of 10 to 30 lbs/ft³ depending upon the thickness required.
Introducing our NEW Thermo-Lite Board ® Core Series 0932. This easy to process structural foam core product is 9 lbs/ft³ and offered in .50" X 48" X 96" panels. Ideally suited as core material for a variety of lightweight sandwich structures, and compatible with a wide range of resins and adhesive processes. This exciting new product has an outstanding price-to-performance ratio. Please contact us today for more information on our Core Series 0932.
Thermo-Lite Board ® Versatile
Manufactured with polymer foam and a matt fiberglass lay-up, this product is a great choice for for a wide variety of uses from floor to ceiling. Available in a density range of 12 to 40 lbs/ft³ depending upon the thickness required.
Thermo-Lite Board ® Tough
Manufactured with polymer foam and a medium-weight woven fiberglass lay-up, this product is acceptable for standard structural loading applications. Available in a density range of 20 to 40 lbs/ft³ depending upon the thickness required.
Thermo-Lite Board ® Supreme
Manufactured with polymer foam and an ultra-heavy weight woven fiberglass lay-up that offers superior mechanical properties, making it the ultimate product where the utmost specific structural strength is required. Available in a density range of 26 to 40 lbs/ft³ depending upon the thickness required.
Sample Applications of
Thermo-Lite Board ®
| Core |
Versatile |
Tough |
Supreme |
| Cores for glass layup applications |
x |
x |
| Cabinetry & shelving |
x |
| Transportation bulkheads & ceilings |
x |
| Marine bulkheads, stringers |
x |
| Marine transoms, hatches & seats |
x |
| Props, signs & theme park structures |
x |
| Wash-down areas |
x |
x |
x |
| Equipment sheds & enclosures |
x |
x |
x |
| Communication towers |
x |
x |
x |
| Staging & concert flooring |
x |
x |
x |
| Marine flooring |
x |
x |
x |
| Lab & cooler walls & flooring |
x |
x |
| Transportation flooring |
x |
x |
