Engineering ToolBox - Resources, Tools and Basic Information for Engineering and Design of Technical Applications!
Amps and Wire Gauge in 12V Electrical Circuits
Maximum current - amps - through a 12V circuit - related to size (AWG) and length of wire
Sponsored Links
Conductors in electrical systems should not be sized with voltage drops exceeding 3%.
For a 12V system the maximum voltage drop should be less than (12 V) x 3% = 0.36 V.
Conductor sizes (AWG) related to maximum current through a 12V electrical copper wire and length of cable - are indicated below:
American Wire Gauge (#AWG)
Length
(feet)
Maximum Current (amps)
5101520253040506070
15 16 12 10 10 8 8 6 6 4 4
20 14 12 10 8 8 6 6 4 4 4
25 14 10 8 8 6 6 4 4 2 2
30 12 10 8 6 6 4 4 2 2 2
40 12 8 6 6 4 4 2 2 1 1/0
50 10 8 6 4 4 2 2 1 1/0 1/0
60 10 6 6 4 2 2 1 1/0 2/0 2/0
70 10 6 4 2 2 2 1/0 2/0 2/0 3/0
80 8 6 4 2 2 1 1/0 2/0 3/0 3/0
90 8 4 4 2 1 1/0 2/0 3/0 3/0 4/0
Note! Failure to use an adequate size may result in a fire. Always secure electric wires with fuses.
  • 1 ft (foot) = 0.3048 m
Wire Gauge Design Procedure
  1. calculate total length of wire from source to device and back again
  2. determine amount of current in wire
  3. determine correct wire gauge in the intersection of amps and feet
Note! Wire size based on 3% (0.36 V) voltage drop in a 12 Volt circuit. Always oversize wires if voltage drop is critical.
12 v cable length maximum amps
print 12V Cable Length Diagram
Example - 12 V Cable and Maximum Length and Current
The maximum current in a 12 V gauge #6 (13.3 mm2) cable with length 15 m is approximately 15 amps according the diagram above.
The maximum current in a gauge #10 (5.26 mm2cable with length 15 m is approximately 5 amps.
Sponsored Links
Related Documents
Tag Search
  • en: amps wire gauge current length AWG
  • es: amperios calibre del cable longitud actual AWG
  • de: Verstärker Drahtstärke aktuelle Länge AWG
Sponsored Links
Engineering ToolBox - SketchUp Extension - Online 3D modeling!
3D Engineering ToolBox Extension to SketchUp - add parametric components to your SketchUp model
Add standard and customized parametric components - like flange beams, lumbers, piping, stairs and more - to your Sketchup model with the Engineering ToolBox - SketchUp Extension - enabled for use with the amazing, fun and free SketchUp Make and SketchUp Pro .Add the Engineering ToolBox extension to your SketchUp from the SketchUp Pro Sketchup Extension Warehouse!
Translate this page to
About the Engineering ToolBox!
Privacy
We don't collect information from our users. Only emails and answers are saved in our archive. Cookies are only used in the browser to improve user experience.
Some of our calculators and applications let you save application data to your local computer. These applications will - due to browser restrictions - send data between your browser and our server. We don't save this data.
Google use cookies for serving our ads and handling visitor statistics. Please read Google Privacy & Terms for more information about how you can control adserving and the information collected.
AddThis use cookies for handling links to social media. Please read AddThis Privacy for more information.
Citation
This page can be cited as
  • Engineering ToolBox, (2004). Amps and Wire Gauge in 12V Electrical Circuits. [online] Available at: https://www.engineeringtoolbox.com/amps-wire-gauge-d_730.html [Accessed Day Mo. Year].
Modify access date.
close
3D Engineering ToolBox - draw and model technical applications! 2D Engineering ToolBox - create and share online diagram drawing templates! Engineering ToolBox Apps - mobile online and offline engineering applications!
Scientific Online Calculator
Scientific Calculator
5 19
Sponsored Links
