THUREN ADJUSTBLE REAR SHACKLES
- Fits 2003-2013 4x4 2500 trucks, 2003-2012 4x4 3500, and 2005-2013 Power Wagons.
- We have been informed these can be used as a lowering shackle on 2003-2012 2x4 2500/3500 trucks.
The grease-able D75 bushing we use as the shackle pivot, provides smooth bind-free shackle swing. When performance suspension is added to the truck, the extension and compression of the leaf springs length, can bind up the tight rubber OEM shackle bushing. This adds unwanted restriction forces, and removing every bit counts. This shackle was originally designed as the key component to our Extreme Travel extended Leafs, but will fit any truck with OEM or aftermarket leafs. As an added benefit, we added the ability to tune the rear suspension height with multiple mounting positions. The closest hole is stock height, the middle hole provides about 3/4" of lift, and the end hole provides about 1.75" of lift.
| Availability | In stock |
| Price | $270.00 |
| Price View | Price Range |
