32 awesome thundercat
Hi all Awesome owners. Have finally gotten my boat toghether in Houston TX. will finish paint next month and be ready for spring fun!
Complete rebuild including new engines, (540 blower 850 hp) drives ( imco extreme) new controls and gauges (lavorsi) , wiring and electronics! Hope to water test next week if temp is 70 or better. will advise results and post photos soon. Any advice on props will be appreciated. will run the first time with the 30 pitch 4 blades bravos I had with the old drives then plan to get 5 or 6 blade props to improve performance and control- thanks for any advice- James |
Re: 32 awesome thundercat
how high is your x dimension? gear ratio? spinning in or out? Boxes? I know of several running very well and may be able to help.
sweet ... another cat in the houston area... I wish I had one!
Ernie |
Let's see some pics!!!! :D
I have not changed the x demention, it is factory standard bravo and the gear ratio is 1:36 but I have added the imco 12" extention boxes and will not have any reference info untill after my first run using the bravo 30" props I have-
| All times are GMT -5. The time now is 07:14 PM. |
