-   Awesome (https://www.offshoreonly.com/forums/awesome-91/)
-   -   26' or 27' Awesome cats (https://www.offshoreonly.com/forums/awesome/166786-26-27-awesome-cats.html)
AWESOME CAT 08-21-2007 05:52 PM
Give me some feed back on what motor,drive,gearing,prop you are running.Speeds would be nice,as well as over all performance.
I am running a n/a 500" BBC with alum heads,dart intake with a 850 cfm holley..Compression is 12/7 to 1 :eek: with JE piston,Carrillo rods and eagle crank.
Gearing is 1:36 on a Bravo 1 spinning a 22" at 4500 rpm's @ 71 mph..I have run smaller props with better speeds but all in all the 22" works for now.
I'm in the process of changing gears to 1:50 right now.
Oh by the way I have the training wheel on my boat(Center pod) lol..
Ok lets hear what you got?????????????:D :D :D
osen007 08-29-2007 11:48 AM
1.50 will make a difference that is what I run with a 3 inch spacer and a 25 pitch 4 blade trophy prop. what is the max lift on you cam I run a .566 .566 you have to get that motor in the 5000 +++ range to get it working right
AWESOME CAT 08-29-2007 04:59 PM
The cam is .700 lift over all..Ran this motor in a small tunnel spinning 6000+ rpm's..
I'm hoping the gear change is going to make the difference..I also have a stand off box..
Whats the best way to measure the "X" dimension on a cat?
26awesome 09-05-2007 08:08 PM
I have a 98 26awesome no pod 3inch spacer 940hp 1.30 gears 28 5blade done by bblades 6100rpm 114mph a little faster with 28 4blade 117mph @6500 more slip and boat does not ride as good as 5blade it is awesome:cool-smiley-027:
