-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   baja transom angle (https://www.offshoreonly.com/forums/baja/104460-baja-transom-angle.html)
articfriends 05-31-2005 04:31 PM
baja transom angle
I'm ordering cmi etops for my 2000 baja 272 because my lightning headers are going to have reversion with my new cam,does any know the transom angle of a 272? I think its 12 degrees but i don't have a good way to measure it,thanks,Smitty
baja36ft 05-31-2005 05:38 PM
Re: baja transom angle
I HAD REVERSION PROBLEMS WITH CMI E TOPS SO IF I WAS YOU I WOULD BUY THE TAIL PIPES THAT GO THRU THE TRANSOM TALK TO RANDY AT CMI HE IS A GREAT GUY.
articfriends 05-31-2005 07:55 PM
I'm buying cmi's with tail pipes thru the transom,thats why i need to figure out the trasnsom angle,does qnyone know what it is? 2000 272 baja
Falcon 05-31-2005 10:41 PM
Why do you need to know the transom angle? The transom should always be 13 degrees from the engine no matter what the transom angle to the boat bottom. Boat companies can vary the transom angle to get slightly more or less trim under. When the engine is bolted down and you raise or lower the front to get the alignment bar in you are setting the engine angle to the transom. The engine isn't necessarily level with the boat bottom.
articfriends 05-31-2005 11:55 PM
Thats what i needed to know,cmi asked for the transom angle before they will build tail pipes that extend thru transom and i wasn't sure what it really was,Smitty
AIR TIME 06-01-2005 05:45 AM
you could put the headers on then make a cardboard jig send it to them fool proof :cool:
