Speed out of a Procharged 25 Outlaw ?
I have a 2000 25 Outlaw with a Procharged (M3SC) and intercooled MCM 502 w/ Procharger competition fuel system. There are no other engine mods. I'm running a Bravo I 28p prop. and am topping out at 71.8 GPS trimmed up / no tabs. It gets up on plane immediately but I was just curious about the top end. Thanks everyone !
Re: Speed out of a Procharged 25 Outlaw ?
What Rpm Are You Turning?
Approx. 4800 RPM.
At 4800 And 12% Slip You Should Be At 74.5 Or So Why
Don't You Try A 26 Bravo And Get The Rpm Up Some I Guess The Rev Limiter Is At 5150? |
If You Can Get A Hydromotive Prop And Try That
A Friend With A 99 Outlaw (25)has One With A 502 And Runs 69.4 It Was Alot Faster Prop Then A Bravo. |
You should get more speed, have you asked procharger what prop you should run
No, not yet. I'll e-mail them next. Thanks. |
A friend of mine has 82 MPH out of a 454, and skip the hydromotive it never held up to the torque of my procharged 502 H2x I run 89.8. A friend of mine helps design the kits if you need help!
What's involved in the 'kit' ? What kind/size prop are you running on your H2X ?
I would think with 570+ HP you should
be running at least in the upper 70's Do you have a boost gauge ? And if so, how much boost are you showing ? .....Fuel pressure too ??? |
