-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Bravo Props (https://www.offshoreonly.com/forums/baja/108047-bravo-props.html)
baja36ft 07-19-2005 11:49 AM
Bravo Props
Anyone Looking For A Pair Of Labbed 26 Pitch Props
In Perfect Cond. Labbed By Throttle-up. 800.00 Or
Trade For A Set Of 28 Bravo's.thought I Would Ask
You Baja Guys And Girls First.
32 caliber 07-19-2005 09:21 PM
Re: Bravo Props
what would be the differance in rpm with your 26 labbed props vs. stock 24's would i be able to turn them at the same rpm as stock 24's?
baja36ft 07-20-2005 03:39 PM
Re: Bravo Props
I Would Say The 26 Labbed Should Be Close To The 24 Rpm But Spinning A Bigger Prop.
32 caliber 07-20-2005 03:44 PM
Re: Bravo Props
I hope I don't hate myself in the morning.....but I bought a set of stock 24's off e bay last night for almost what you want for yours.......I am going to try these out this weekend...if they aren't what I'm looking for and you still have yours you may be hearing from me......
baja36ft 07-20-2005 04:15 PM
Re: Bravo Props
If I Were You I Would Contact Julie At Throttle-up
727-531-2255 And Ask Her About The (prop)loaner
Program She Has If You Buy Used Props That Someone Took To A Bad Prop Shop You Will See Bad Results So Watch What You Buy. I Found Out The
Hard Way.
