-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Drive settings (https://www.offshoreonly.com/forums/baja/110689-drive-settings.html)
Smitty 08-22-2005 10:57 AM
Drive settings
I have a 2000 36 Outlaw and I need to know what is the preferred settings for the drives concerning alignment. I did check the tech area and what I saw there tells me with props spinning out I should be toed in about 1/8 but it was not specific to this boat.
Can anybody confirm what it should be. I have not measured it but it appears to be toed in about 3/4 of an inch.
Thanks,
Smitty
baja36ft 08-22-2005 11:34 AM
Re: Drive settings
Thanks,
Smitty
MINE IS IN 1/8 INCH!!!!!!
Dock Holiday 08-22-2005 11:59 AM
Re: Drive settings
Straight (parallel) to 1/8 inch in.
I have ran mine both ways and have not seen any difference.
The important thing is to run your drives up to where you like to operate the boat and check them at that point.
I have been told that if you have a drive alignment issue that from static (all the way down) up to normal operating position it can change.
Good luck
JaayTeee 08-22-2005 01:07 PM
Re: Drive settings
Mine were 3/4" out, I set them to
1/8" in.
Before the adjustment, there was
a "wander" issue, after, no wander.
Smitty 08-22-2005 09:53 PM
Re: Drive settings
Thanks Guys !!!
I measured mine tonight and it was toed in 5/8 of an inch. It is now set at 1/8 of an inch. Hopefully I will see 1 mph more out of it !!!
I will report any speed increases if there are any.
Smitty
