-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Anyone with a 36 calculate your prop slip? (https://www.offshoreonly.com/forums/baja/117484-anyone-36-calculate-your-prop-slip.html)
baja36ft 12-15-2005 06:44 PM
Re: Anyone with a 36 calculate your prop slip?
Originally Posted by 32 caliber
I run mine out, I tried them in but it did not handle as well, I tried every prop I could..mirage, bravo1, hydro's...then I tried the revolution 4's because BBlades said they worked well on baja's.. None of the other props even compare to these! The boat feels like it's 10' longer and 5k heavier. The ride is unbelievable! I was ready to sell it and go bigger to get a softer ride(which I did not want to do) until I tried the rev4. I'm not looking for the highest top end, in Lake Michigan it get quite rough, top speed doesnt do any good if its pounding you to death..I can outrun most when its rough because of the way it rides now. I wouldnt change a thing on it now!
THAT MUST BE A GREAT PROP I REALLY LIKED MY 32 THAT WAS ONE NICE BOAT SORRY I SOLD IT WHEN I WAS DONE WITH MINE PUT 540'S IN IT AND IT RAN 86 GPS WITH HYDRO'S (29'S)SPINNING IN THAT WAS THE BEST FOR ME.
GOOD LUCK BBLADES I HEAR IS GOOD!!!
BajaRunner 12-16-2005 07:59 AM
I talked with throttle up and they said my prop slip was 13%. I told them i was using the go-fast website to calculate it, and they said you have to calculate a bravo 1 26p as a 25p. They said they are actually a pitch lower than stamped ??? they also said slip numbers on a deep v with a 4 blade should be 11-14%.
BajaRunner 02-06-2006 10:26 AM
Dock, what were your results with the hydro p-5's?
Dock Holiday 02-06-2006 10:41 AM
Haven't got the boat back in the water yet. I'll keep you posted.
BajaRunner 02-06-2006 10:43 AM
sounds good. ive almost got the fine tuning done, and ill really concentrate on props. I tried hydromotive Qiv's this weekend. Much better slip #'s but lost 500 rpms. Felt like they slipped to about 40mph too.
BajaRunner 02-07-2006 08:32 AM
Originally Posted by baja36ft
71MPH WITH 6 PEOPLE AND 3/4 TANK OF FUEL IS PRETTY
GOOD WITH MY 36 I DID 74.8 BEFORE MOTOR WORK.
I USE 27 OR 28 PITCH HYDROMOTIVE'S NOW AND DOING
77 TO 80 DEPENDING ON LOAD AND CONDITIONS.
SORRY TO HERE ABOUT THE HUB.DID YOU TRY SPINNING THEM IN?
Stan,
Got a question for you and dock. im spinning my 26's at 5500 and still not getting what you too got for speed stock. Im confused how im spinning 150 rpms over the rev limiter on a stock 500, but still not as fast. what props were you running stock?
baja36ft 02-07-2006 04:22 PM
Stock Was 26 Bravo I Think Dock Had The Same (but He Can Tell You) Mine Were Stock Not Labbed What Year Is Your Boat? My And Dock's X Are The Same That Might Have Some Thing To Do With The Speed.
Make Sure That Your Tack Is Right Some Times They
Are Off .JUST BECAUSE YOU ARE SPINNING HIGHER RPM DON'T MEAN YOU ARE STILL MAKING POWER WITH THAT CAM IT MIGHT BE DONE AT 5200.
BajaRunner 02-07-2006 04:25 PM
Ill check the tachs. boat is a 2000.
oh, were you in salt or fresh?
baja36ft 02-07-2006 04:26 PM
Salt, Give Me A Call If You Want.
