Anyone with a 36 calculate your prop slip? >
Old 02-25-2006 | 11:23 PM
  #61
customtouch's Avatar
Default Re: Anyone with a 36 calculate your prop slip?
Originally Posted by BajaRunner
boat is at the fiberglass guy today getting the a/c pickup removed.
dock did you use the same fitting on the back or get a new pickup?
Who did you end up using for your glass work?
customtouch is offline
Old 02-26-2006 | 07:10 AM
  #62
BajaRunner's Avatar
David, Its the guy the ski dock uses. his name is jay. heard of him?
BajaRunner is offline
Old 02-26-2006 | 10:40 AM
  #63
Does not immediately ring a bell. How ever that does not mean I don't know him!
Old 02-26-2006 | 11:45 AM
  #64
BajaRunner's Avatar
well at least hes not on your chit list
Old 02-26-2006 | 11:55 AM
  #65
Good Point!!!!!
Old 02-27-2006 | 02:21 PM
  #66
BajaRunner's Avatar
anybody have a guess on what it will do? Im getting anxious! I know ill probably have to do some prop work to get 100% out of it.
Old 02-27-2006 | 02:36 PM
  #67
Dock Holiday's Avatar
Charter Member #34
I wish you the best of luck and the best of results.
If you don't expect much then every little bit you gain seems like a lot. I have told everyone that with all the work we have done that I expect to loose 3 MPH!!!!
We are leaving after work tomorrow to head down and pick our boat up finally. I'm taking two sets of props to try Wednesday in that beautiful 70+ degree Florida sunshine.
I'll let you know how see does.
Dock Holiday is offline
Old 02-27-2006 | 02:38 PM
  #68
BajaRunner's Avatar
Im very curious to see how yours runs as well. Did you end up changing cams?
We have 80-85 degree temps this week That will make for some nice testing.
Old 02-27-2006 | 03:30 PM
  #69
Charter Member #34
Yes, the only thing we changed on the engines this time was the cams. Used the Crane 741 which is the same as used in the new 525's.
Old 02-27-2006 | 03:36 PM
  #70
BajaRunner's Avatar
are you running gils or an aftermarket exhaust?
I went back and forth on the 731 vs 741 and the outcome i was told was the 741 made more power BUT
1. there was a better chance for reversion
2. it was in an unusable rpm range.
BUT the 731 cam isnt much more cam than the stock hp500 carb cam.
