-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Testing the 36 tomorrow (https://www.offshoreonly.com/forums/baja/121503-testing-36-tomorrow.html)
BajaRunner 01-29-2006 10:38 AM
The boat is ready at Full Throttle Marine. Just did head work, cam, bumped up the compression, bumped the rev limiters, did the valve springs/valve job, added adjustable timing chains and head gaskets, my couplers were shot so they were replaced. Doing the sea trial tomorrow, hoping to pick up a few mph. I dreamed last night I got to the ramp and forgot my props, there loaded in the truck now :D Ill report back tommorrow when i get some gps results. :evilb:
TEAMBAJA 01-29-2006 10:48 AM
Re: Testing the 36 tomorrow
Dont forget the pictures! :chimp:
baja36ft 01-29-2006 10:56 AM
Good Luck Hope Every Thing Is Ok.
Dock Holiday 01-29-2006 06:46 PM
Good luck, we are all waiting for your reports of increased speeds!
JaayTeee 02-01-2006 05:46 PM
It's "tomorrow"........we're waiting :D
Dock Holiday 02-02-2006 08:14 AM
Still Waiting?
BajaRunner 02-02-2006 08:28 AM
The sites been down everytime i tried to get on.
We need to work on the carb tuning. It accelerated VERY nice, but only saw 1mph increase. It hits a wall at 5450. The plugs were fouling out due to it being too rich and it smelt like a gas tank idling.
Also, my props need a little cup as the front of the boat was dragging (due to the a/c we think) and julie at throttle up thinks i can pull the slip down 2%.
Were wondering if the carbs are too small to go to 5600. It had a ton of power, and stopped at the 5450 mark.
Ill keep you updated on it all. Im also thinking of pulling the a/c pickup thats on the bottom. that thing is huge.
So not there yet, but getting closer. The 731 cams sounded very nice along with the bump in compression.
JasonSmith 02-02-2006 10:09 AM
What is your setup engine wise?
BajaRunner 02-02-2006 10:14 AM
hp500's
JasonSmith 02-02-2006 10:22 AM
What size carbs? The stock Holleys? I had to go to a 1050 Dominator to get my 502 to spin 6000.
Dock Holiday 02-02-2006 11:18 AM
I'll keep you posted on how my boat turns out.
We pulled the A/C fitting off the bottom, took the hook out and trued the last four feet of the hull.
That fitting is a BIG problem. I know for a fact it was causing a lose of speed and creating bad water on the port drive and prop.
We should have it back in the water soon.
BajaRunner 02-02-2006 12:18 PM
The stock 500 carbs are 800's. we are thinking they are too small to turn the 5600, may have to go with 850's.
BajaRunner 02-02-2006 12:20 PM
Im very interested to see how it does. Im wondering if that isnt a lot of my problem. Everybodys 36 does 74 from the factory EXCEPT mine. maybe that a/c fitting is costing 1-2 mph. If so, thats a cheap fix for the gain.
Oh dock, will you post some pics of how yours looks now?
Smitty 02-02-2006 12:46 PM
I'm very interested to hear how Dock's boat rides now that the hook has been removed. I have heard on Baja's that taking it out causes it to porpoise alot more.
Dock please let us know !!!!
JaayTeee 02-02-2006 04:48 PM
Do you have carb spacers on them ?
BajaRunner 02-02-2006 04:49 PM
no, but thinking about adding them. what do you think about the carb size?
JaayTeee 02-02-2006 05:15 PM
It's "iffy".
Spacers increase plenum volume,
that can help compensate when
carb size is a limiting factor.
And, they're relatively cheap, and
relatively easy to install.
baja36ft 02-02-2006 06:57 PM
IF YOU ARE RUNNING RICH AT IDLE I WOULD TRY A 2INCH OPEN SPACER BEST THING IS TO PULL A PLUG AFTER A
WOT RUN AND SEE WHAT IT LOOKS LIKE BUT WHEN I DID
MINE WE PUT A 850 CARB ON WHAT IS THE TIMING SET AT?
customtouch 02-02-2006 08:44 PM
BajaRunner, Sorry to cut you short today on the phone. When I tried to call you back I didn't have your number. To answer your question, the only person I know of for glass work around here would be Rick George out at Emerald Point Marina. I have not met him personally or had any work done for me by him, but I have been told that he is suppose to be good. The only other people that I have heard do a good job is Custom Boats of Austin, but then again I have not personally had anything done by them. Sorry I can't give you a definate answer but I hope this helps. :drink:
BajaRunner 02-03-2006 07:54 AM
Timing is at 34 degrees. We pulled a plug and it was black, but bob said that its hard to read plugs, because as soon as we back to idle, they turn black.
Im wondering if i need an 850 or if its something else.
We were thinking of doing the spacer and 850 at the same time, I just want to make sure i need it before spending $1200 on some new carbs.
Thanks david, ill give em a call.
AeroSpeedMarine 02-03-2006 11:51 AM
hey bajarunner i had some 540 bulldogs i am selling the intakes and the carbs make you a hell of a deal i just had the carbs done by dean nickerson.. 850's chopped ..
BajaRunner 02-03-2006 12:14 PM
I sent you a pm.
baja36ft 02-05-2006 09:15 AM
Good Talking To You Jason If I Could Help In Any Way
Call Me.
Stan
