-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Hatch Actuators (https://www.offshoreonly.com/forums/baja/129851-hatch-actuators.html)
Smitty 05-11-2006 10:22 AM
Hatch Actuators
I have a 2000 36 Outlaw with the actuator in the center of the hatch at the front. It died last night, and in my haste I failed to think about measuring it for a replacement. Since the boat is 30 miles away I was wondering if anybody knew the correct size or if you have a 36 could you measure what you have so I can get one today.
Thanks!!!!
Smitty
Steel Outlawed 05-11-2006 10:47 AM
Re: Hatch Actuators
The 24" will work perfect. I bought mine from CP Performance. It's Polished Stainless and it looks great.
Smitty 05-11-2006 04:49 PM
Re: Hatch Actuators
Steel--
Thanks for the info. I called Trick marine and have one on the way !!!
Thanks !!!
Rocko C 05-19-2006 05:28 PM
Re: Hatch Actuators
I just received two actuators for my 25 Outlaw but was accidentally shipped two different ones. One is rated for 300lbs and the other 600lbs. Does anyone know how much load is placed on each actuator in a 25 Outlaw. The reason I even care is that the lighter duty actuator is twice as fast. Either way, I'll have to return one of them to have a matching set. Thanks for your help !
Rocko C
Steel Outlawed 05-19-2006 08:42 PM
Re: Hatch Actuators
Rocko C
You should not have any problems with 2 #300 actuators.
Rocko C 05-21-2006 05:19 PM
Re: Hatch Actuators
Ok, I'll go with the faster ones. I can't imagine what it's like to not have to wait forever for the hatch to open. Thanks for your help, Steelware.
