25 Outlaw w/ 502 Mag...Prop issues
We are running a 25 Outlaw with a 502 Mag and spinning a 23 Mirage Plus. This was the first weekend we used this boat in rough water at LOTO. With a full tank of fuel and about 6 people on board and in rough water, the prop started blowing out at about 4000 rpms. Some times I had to completely come off plane to get the prop to bite again. Has anyone exprienced this before? I assume we need a 4 blade, but I thought 23 Mirage Plus was the prop to run. Give me some suggestions.
Re: 25 Outlaw w/ 502 Mag...Prop issues
I had the same problem with my 25 Outlaw. I went through many props before I found the one that worked the best. Before the supercharger I had a Bravo One 24 p labbed. After the supercharger I had a 28 p Bravo One Labbed by Mercury.
Try a 23 - Revolution 4
I ran a merc labbed 25 on my 25OL with 496HO and it was really good. Lots of grip and a WOT at 67 GPS mph at 4900 rpm any time. Tried a 23" Mirage Accelerator but it just didnīt feel as connected as the 4 blade.
Now I have a 525 and an Imco ext box and the same game takes place 12 mph further up the scale! |
I had a similar problem, I went to a labbed 24p 3 blade. So far no problems.
I Have 2 Friends With 25 O/l And They Use 22 Pitch 4 Blade Hydromotives Works Great.
Does your prop have vent plugs?? thre would be 3 near the base of the prop inbetween the blades
One of my buddies put a 4 blade on his 25 and it slowed him down quite a bit, but he said it had great handling.
WILD CARD 09 what brand ex-box did you use and did you see better handling?? I just put on a 2'' shortie on my boat but it won't hit the water for a couple of weeks I have full hdy steering just getting in too. have 650 hp510 in her. whats your speeds too
The 23 Mirage + does not have vent plugs.
| All times are GMT -5. The time now is 08:08 AM. |
