Best mods and prop for a 496
I cant quite spend the money on a $3,500 exhaust system. What's the best way to get more power or a few mph out of a 496 mag in an 05 25 Outlaw?
Also, what's the best prop for this boat? I've got a Mach 24P 4-blade on it now. The boat is a little slower, but it rides better. I'm getting 4,800 rpm at WOT. |
Re: Best mods and prop for a 496
cant you upgrade the ECM, cam, and throttle body for under $2000? These are all the parts that make the 496mag into the HO.
get an HO ECM , a Raylar BCK 103 Cam , a pair Raylar aluminium heads and pull out the turbulators from the stock exhaust and you will have about 500 HP for about 5 K
thats a gain of 125 HP or 40 $ / HP You will also get about 100 pounds less weight |
What is the turbulators and how do they come out, also does the HO have them?
thats a gain of 125 HP or 40 $ / HP You will also get about 100 pounds less weight Thanks for the replies so far... |
| All times are GMT -5. The time now is 06:29 AM. |
