-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Removing the back seats (https://www.offshoreonly.com/forums/baja/144809-removing-back-seats.html)
Lt for Life 11-10-2006 04:59 PM
I am in the process of switching motors in my 1997 27 Islander. In order to fit the new motor in I was told that the center section of the rear bench must be removed as well as rear back rest. The problem I have is that I cant find any mounting screws/ hardware holding the back rest in place. The center seat came out easy but the back rest is becoming a head ache! :mad: Please HELP!!!!
Lt.
weekend warrior 11-10-2006 09:19 PM
Re: Removing the back seats
Yea - I'd like to know how to remove the vertical portion of my back seat in our 29 OL as well. The local Baja dealer and mechanics don't know - somebody out there must know!? Help!
kennyo 11-12-2006 07:40 PM
My 97 272 had one or two ss wood screws holding the sides of the backrest of the back seat. Reach back in the side compartments and feel for a screw bead into the side of the seat. after that you have to wedge it out. The motor has just enough room to come out. It might come out w/o taking the seat back off. Mine has a procharger pulley is why i have to take mine off.
Lt for Life 11-13-2006 03:42 PM
Kennyo,
Thanks I will check it out tomorrow. :D
Lt.
soldsoul4foos 11-13-2006 08:38 PM
Just curious..what did you have, and what are you putting in for an engine? Thanks.
http://users.adelphia.net/~wgwarren/...t/IMG_0076.JPG
Wild Card 09 11-14-2006 04:22 PM
LtfLife, I checked with my buddy. His `93 272 is just the same as kennyo´s ´97. Reach back in the lower side storage and you will be able to find the 2, or 3 screw heads. He said that after you´ve removed the screws expect to have to use alot of force to remove the backrest - if it has never been removed before. The vinyl sticks pretty good to the inner walls of the cockpit. Maybe spray a litlle water and detergent down the sides to free things up.
Ironmanwb 11-16-2006 08:04 AM
Grease her thighs and push..........oh sorry I thought this was a different thread :D
Lt for Life 11-16-2006 08:27 PM
Dropping a 496ho in. Looking to hit mid to upper 60s.
Lt for Life 11-16-2006 08:30 PM
Wild
Thanks again for the help! I will test out the soap and water theory on Saturday. Hopefully it will come out!
Lt.
