Low coolant in tank
Just uncovered the boat in anticipation of spring tune up. When I removed the cover from the drives I noticed a little bit of pink fluid. When I opened the hatch, port side coolant tank was very low. The engine was apparently properly winterized. Leak? Any idea? Should I be concerned. They are 496HO's. TIA.
Originally Posted by fatdaddy
(Post 2105117)
Do a search in the General Q&A technical area for 496 Coolant Leak and you'll find some good info. Here are a couple of links: http://www.offshoreonly.com/forums/s...6+coolant+leak http://www.offshoreonly.com/forums/s...6+coolant+leak Hope that helps, Chris |
Thank you so much for the post. The links were quite informative and I'm very relieved to hear of the relatively simple fix.
| All times are GMT -5. The time now is 11:42 AM. |
