top speed
what is the top speed you should expect from a 36' baja outlaw with twin 502 mags 24p 4blade prop 1/2 tank of gas on a light chop? anyone out there getting better than 63.9mph gps? is there more speed there that i'm not tapping into ? don't want to put prochargers on just yet. thanks for your help:evilb:
What is your maximum rpm attained?? Sounds like you are close to where you need to be. Remember the 36 is a big heavy hull so it will take alot of power to go significantly faster. I speak from experience.
Originally Posted by KDAWG
(Post 2205333)
raised the X dimension on those, and the 4 blades may be costing you a couple mph up top. I remember seeing boating mag test one back in 98' or so W/502's and it ran around 67, and it had 3 blades. This time of year ( heat and humidity) is also not best for getting max perf. out of them. I'd kill to be only 3 mph off my best top speed at this time of year:D a couple of weeks ago It was - 10:eek: |
You might check with Dock Holiday. He might have some information for you.
thanks for the input i 'm new to the big boats and i was just wondering what to expect. we bought for the ride, at least that is what i tell my wife. need more power!!!!!!
| All times are GMT -5. The time now is 10:36 PM. |
