What are Baja "Offshore Engine Mounts"?
I noticed in the Baja brochure, that the 26' and up Outlaws have "Offshore Engine Mounts", while the 20 and 23 Outlaws do not. What's the difference between these two mounts? Will the 20 and 23 engines pull out of their mountings if the boats are used offshore?
Michael |
I belive it is Thru bolted at the stringer v just lagg bolted into stringer. ?
Quinlan |
The offshore is a plate mount connected to angle aluminum and thru bolted. It is non adjustable. The regular mount is a pedestal type and is adjustable. With regular mounts the adjustment may change with time and abuse but it won't come loose from its mountings.
Jim |
These pedestal mounts are just lag bolted in?
Michael |
Originally Posted by Michael1
(Post 2315203)
Michael John |
1 Attachment(s)
Baja has long used engine mounts bolted to aluminum L-angles that are through bolted to the stringers. This includes the 20 Outlaw and 23 Outlaw and this design has been used on most performance boats. Just about every review of the boats I have ever read praised Baja for using this tried and true method instead of going to the cheaper less stout design of lag bolting a riser to the stringer such as you would find in a family runabout.
Baja has recently designed a more solid type mount that is utilized on the newer boats they are building. I attached a picture. It it more of a cradle mount and eliminates the adjustable riser mount. |
1 Attachment(s)
It is not a great shot, but here is part of the 25 Outlaw mount.
So since these types of mounts are not adjustable, I take it that you dont ever have to worry about checking the alignment of the outdrive ??
Originally Posted by baja bailey
(Post 2315572)
Originally Posted by Specialized
(Post 2315303)
Yes, but they also have a retaining angle that is thru bolted to the stringer to keep the mounts from just tearing out. but the angle will allow the lag to back out a bit. I think the offshore mounts have been a great addition to what seems to be a brand that is evolving into something a lot better than in the past. Watch out Reggie:D
John |
| All times are GMT -5. The time now is 04:04 PM. |
