-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Baja 38 (https://www.offshoreonly.com/forums/baja/179512-baja-38-a.html)
amarek 02-10-2008 10:09 AM
Baja 38
I repowered my Baja from 502 MAG to 496HO, my mechnaic told me I need to replace my 3blade props with 4 balde props, which one should I buy?
thanks
AM
THLWL 02-10-2008 11:30 AM
I had an unlimited supply of Mercury props when I owned my 1997 38' Baja. I tried the 22, 24, & 26" Bravo 4 blades. The boat hated all three. Blow out, ride levelness, - all were off. I think the 4 blades lifted the rear too much. I then tried several sizes of the Mirage 3 blades. I had 502 MPI's and the 21 was not enough and the 23 was too much for large loads. I had the 23's bent to 22 and was perfect. Try and find someone with 4 blades on a 38 Baja and see if they are working ok. I didn't try other mfgs. (Hydromotive, Herring, etc.).
eddie 02-10-2008 12:08 PM
I've got a buddy with 26 Bravo I's on a 1993 that we repowered with 500 EFI's. I'd call Breet at Blades and talk to him, he will get you set up.
AIR TIME 02-10-2008 12:57 PM
rev4 by merc would help if the b1s didn't call brett:D
amarek 02-10-2008 05:16 PM
Do you have a contact info for Breet at Blades,
thank you
amarek 02-10-2008 05:18 PM
do you have a contact infor for Breet ?
eddie 02-10-2008 06:08 PM
Yes:
Brett A. Anderson
Shop 920-295-4435
FAX 920-295-4436
www.bblades.com
kr1276 02-10-2008 07:39 PM
I ran revoluton 4's on my 38 repowered with 496's and they offered the best overall performance.
amarek 02-11-2008 08:38 PM
which pitch?
thanks
AM
kr1276 02-12-2008 02:32 PM
I had 1.36 drives and ran 22 pitch that had been reworked to 23's
